Shelldrake
Hello,
I am resurrecting a '66 3 hp Lightwin with the folding shaft option. Removing the water pump housing is is more complicated than normal because the connecting collar on the lower drive shaft is in the way of sliding the housing up an off the shaft. I ended up pulling the shaft out of the gear housing so that I could slide the water pump housing and impeller off. The only other way to accomplish this would be to drive the two pins that hold the shaft coupler and spring out of the lower drive shaft. Re-installing the shaft into the gear box is a challenge, and the coupler pins are frozen in the shaft.
Has anyone faced this issue? Any recommendations? This seems to be a weak link in the design of the two piece, folding drive shaft.
