I have run a search, haven't come with a good answer. I think it's a 1988, 60 HP, friends kids motor they purchased. I got called in late in the game, they had it running on Ether
,and then it wouldn't run at all, before I got called. Compression is okay for the age, I confirmed there is one bad coil. Fuel pump is currently disconnected, pumped up the bulb and had him crank it while holding pressure on it, nothing, tried WD-40, nothing. Put #1 cylinder at TDC, flywheel appears to be about 40 degrees after TDC. Do they have a Woodruff key that may have sheared? I found some parts diagrams and I don't see one, have not come across a press fit flywheel before. It does have a lock nut on the flywheel, if there is no key would you put #1 at TDC and line up to the 0 mark and torque it down? Hate to pull the flywheel if I don't need to. The Timing advance adjustments have not been messed with.
Thank you, literally asking for a friend!
