Flywheel magnets 200hp Johnson
tom
" Hi,
Okay, I got the flywh
" Hi,
Okay, I got the flywheel off. One magnet was broken in two and two others were chipped. I bought three new magnets and epoxied them in place, along with the three old magnets with a 7/16" spacing between them. I then read one of the conversations that was posted saying that they should be in their original position. By that I hope you mean excactly what I did. Not that they had to be placed in the original factory position (which I have no way of knowing). Please tell me it will be okay (I need emotional reinforcement).
Thanks,
Tom "
" AS LONG AS YOU HAVE THE POL
" AS LONG AS YOU HAVE THE POLARITY CORRECT, YOU ARE IN GOOD SHAPE. "
" There is a slight bevel on o
" There is a slight bevel on one edge of the magnets. That bevel must be facing the outside edge of the flywheel, not the dome side.
When the flywheel is in the installed position, the magnet bevel would be facing down towards the powerhead.
Joe (30+ Years With OMC) "
" Thanks!!! Yep, that is just
" Thanks!!! Yep, that is just the way I have. Okay, one less thing to worry about.
Thanks again.
Tom "
