[FONT="]Can anyone help with a bit of advice. I have removed the engines from my boat (tamd 41b) and the drives (290 dp) from the transom shield. I did this by removing the bolts from around the flywheel cover and pulling the engines off the splines. Since found out that its not the best way of doing it. I am now left with the flywheel covers attached to the transom shields and pretty much stuck fast. I have removed the tabbed bolts from the ring in the transom shield. As yet I haven't removed the ring though. My next task is to push the bell housing forward out of the transom shield. I believe that there is a threaded hole at 12 oclock and 6 oclock which can be used to press out the flywheel cover. Does anyone have any experience of removing the flywheel cover in this way or is it a crow bar and hammer job.[/FONT]
[FONT="]Many thanks in advance[/FONT]
[FONT="]John[/FONT]
[FONT="]John[/FONT]
