"Clymer also says something in
"Clymer also says something interesting that I wasn't aware of, something along the lines of "tilt motor forware until the prop is out of the water to ensure water doesn't travel up thru lower unit"?? I don't have the book in front of me but this sounded awfull strange to me since there is a tilt switch that should turn the motor off. On top of that, what water travels up the lower unit other than what goes into the water intake vent. When I return to the dock I usually tilt the motor up, put on the muffs, lower the motor with the freshwater on and run at 1500 RPM's for about 5 minutes. After this I turn off the motor and leave it raised up while remaining at the dock.
Tell me this is the correct procedure...Please!"
