Flushing Tohatsu M5B motor...
Just got this motor, and in the manual it states that in order to flush the motor, you need to "Remove the Water Plug on the Drive Shaft Housing and screw the flushing plug." Two questions:
1) Where on the Drive Shaft Housing is the Water Plug?
2) In the parts kit I have what appears to be a Flushing Plug but the intake diameter is small and if you stuck a hose around it most of the water would probably just spill out....
thx
I just looked at a PDF file of your engine. The plug is under the engine.
