Flushing mercruiser 4.3l with external pump
Jewfiesta
Hi! This might be a silly question, but here goes
Is it possible to flush the cooling system while the engine is off, with an external pump connected to the water inlet hose coming from the sterndrive impeller? Or does the engine need to be running to control the valves in the cooling system or something?
Your not going to be able to push much water past the pump in the leg
You could put a Tee on the intake hose and push it thru that way
thermostat needs to be open as well, as mentioned wont get water past the impeller in drive.
Why are you opposed to running the engine while flush water is provided?
Yes I assumed pushing water through the impeller while it wasnt running, was impossible. So my idea was to attach the pump to the hose coming from the sterndrive impeller, thus bypassing the impeller.
I was gonna bypass the impeller by connecting the pump to the hose coming from the impeller.
Im considering making a flushing system for on-water use. It would make the plumbing less complicated if I could flush while the engine isn't running. If the engine isnt running, theres no need to add a second valve just for dumping the impeller water back overboard.
Can you explain to me in simple terms how this works? Im relatively new to boat engines
It’s not different than automotive engines in respect to thermostat. Thermostat opens when engine is at temp , which is 140 f or 160 f for most marine engines with open cooling. Thermostat lets hot water out of the engine when open and cold in. Whether you are flushing or trying to winterize by sucking antifreeze in , unless thermostat is open engine block will not get fresh water.
To be honest you are making this more work than needed. Even if boat is slip kept put muffs on drive when all the way up by hanging off swim platform and run engine when at temp to flush salt water out .
Ok, thank you! I honestly believe it's more work to hang off the the swim platform with the muffs every time I've used the boat. I can easily put together some hoses and valves and just plug the slip's garden hose to it.
if you pursue your flushing concept to fruition, make sure you use high quality hardware...any leaks (in or out) won't be a good thing...
Engine needs to be running for an effective flush on a raw water i.e. no heat exchanger, engine,,, there is a circulating pump inside the engine..
