"can anyone help me with my ge
"can anyone help me with my gen2 305?? I keep the boat in the water during the winter and after the hard freeze I started the motor and let it run for about an hour. a few weeks later I went to start the motor and it cranked aprox 4-5 times and locked up. I pulled the starter and found the nose had cracked completely off,blaming it on a bad starter I put a new one on and again after 4-5 rotations it locked up again. After removing plugs I found all cylinders full of water.I then pulled both heads and found both gaskets in bad shape. after checking the heads for warpage I redid the valve seals,gaskets and put it all back toghether. it again flooded just as bad and just as quick. could it be both heads are bad?? and should I be concerned about the block??"
