Peter Devil Ears
Hi, I have a 1979 175HP Black Max. When I pump the bulb before the first start of the day, fuel comes out of the carbs, all of them, as if the float levels are incorrect. I checked the service manual and it states the when I hold the carb bowl upside down, the float should hang 1/16th or 1.6mm from the lip of the bowl. I adjusted all of them, and the needles seem OK since I cannot blow through the carb inlets when I hold the bowls upside down. Still, when I pump on the bulb, fuel comes out of all carbs. Is it because hand pressure is alot more than pump pressure, forcing more fuel past the needles? I remember the last time I saw this, the boat still ran fine and did not leak fuel once running.
