ptownbubba
I have a 2006 Optimax 75 HP, on a pontoon boat, it came with an aluminum, 14 x 13 pitch prop. I see there are a couple flo torq hubs available. When I replace the hubs,,, is there any reason for my set up to need / use the III instead of the II ??? My thoughts are, the II is the one piece hard plastic sleeve and bronze spline-d insert/adapter, the III has a 2 piece plastic sleeve, with a longer spline-d adapter. I have both long and short spline-d adapters on the bench, which one is the 'best' to use ? I just took off a replacement prop, it had a 2 piece plastic sleeve,,, but a short adapter,,,, was that wrong,,,, the plastic sleeve is all tore up, and bronze insert is sorta' jammed in there,,,, need to press it out. Any thoughts on correct hub ?
