Flash codes on 2001 DF50
H
Hayes
Guest
"When turning on the ignition
"When turning on the ignition key, I get all the lights for a second, then the tach goes to 1000 indicating between 100-150 hours(which is correct), the beeper beeps once and then I get 5 flashes of the rev limit light. I use the engine 1-2 times a week with no problems, I just can't find out what the 5 flashes mean. Can anyone help? Thanks"
"5 flashes is not addressed in
"5 flashes is not addressed in the owners manual. 3 flashes would be that it was not reset after an oil change. Resetting does not clear any flashes. Other than indicating a required service,(which isnt due)the flashes on the rev limit light are not supposed to occur until engine hours are up in the thousands. I called two different Suzuki techs and neither has run in to this before. I thought maybe someone on here might have."
"I have had some problems with
"I have had some problems with the RPM diagnostic
indicator as well....I believe the problem could be in the ignition switch (dirty ground)....I replaced
mine and the problem was solved. NO guarantees this will work for you but, it might be worth a try."
"I checked out the ignition sw
"I checked out the ignition switch and made all new connections.........no difference. Anybody with any other ideas? If you don't want to post, e-mail me at [email protected]. Thanks, Hayes"
"Check your e mail address it
"Check your e mail address it did not work.
I'm looking at a shop manual for DF 60&70 and they show a self diagnostics page
showing flash patterns for five flashes * **** code 14 Cylinder temp sensor
** *** code 23 IAT sensor
*** ** code32 Map
sensor 2 (Sensor Hose)
I don't know if this will help for your motor but you might look in to
these codes .
The manual is for 1998 to 2002 Suzuki and is the one the dealers use.
Hope this helps,
Norm"
"Thanks Norm. [url=""]haynan@
"Thanks Norm. [email protected] is my e-mail, not sure why it did not work. I think the 60 and 70 are a little different than the 40 and 50, but I will suggest those codes to the guy at the dealership. I would really like to learn how to clear it and not worry about it unless it came up again."
