Keithm18
Hi guys. I need your help again please.
In reading my manual i have found that my motor should be fitted with a temperature reading unit that will enable me to fit a temperature gauge.
As I understand it on the Port (Left) head of the motor there is a two wire sensor with a plain tan wire that should be connected to the overheat horn and the black one earthed on the head.
On the Starboard side (right) is a sensor with only a single wire which is tan with a blue stripe that runs into the harness.
In the front at the remote I have found that the tan wire with the blue stripe is not connected to anything.
Here's my question. the wiring diagram in my manual shows that the tan wire should go into the temperature gauge and is also says the tan wire should go the warning horn, but says nothing about where the tan and blue wire should be going...
So I have a few questions.
Which head is wired to the overheat warning horn in the remote? are they both through some kind of splice in the harness?
Which wire can I connect to the temperature gauge to read the effective head temperature? the blue and tan or just the tan wire?
Should the blue and tan be connected to anything?
Lastly can I connect a normal Automotive electrical temperature gauge to the correct wire from the sensor in the motor, or do I have to get a specific gauge at $70 plus?
As always thanks for the help.
