fisherman year with serial number
hamelking
hello i have a evinrude fisherman 6 hp and i want to know the year, i have the serial number 6402c c 74073, i broke the gear at the end of the shaft and i want to know if i need a new one or it can be fix.... thank you
1974 model year----------------What shaft and how badly is the " gear " broken-----------Information is needed to get your answers.
thank for the year .......the gear is broke at the bottom of the shaft (that's the one who make two other one in the feet turn the propeller) in fact i hit a rock with the motor thank you
Take it apart --------------Inspect driveshaft bearing surface above the pinion ( broken gear ) and the bronze bearing in the gearcase.------------------------Pictures will always help.---------------------------Parts #'s and prices available here and --------------shop.evinrude.com.
broken part fisherman 001.jpgthats the part i have broke do you think i'm gonna need a new shaft....
Correct $ 300.00 for the shaft.----------------------If you have access to machinery / shop then there are options to repair the bottom of yours.-----------------Myself I would never spend that kind of money for a 6 HP shaft , I have boxes full of parts to make a " no money fix " for that.
No I don't-------------The ones I have are damaged in the pinion bearing area.-----Awaiting repair ( sleeving ) to 0.550 " which was the size for earlier models.
