Fish line on prop shaft help
jaxnjil
"got 73 19ft bayliner with 165
"got 73 19ft bayliner with 165 in line 6. took for a trial run and when got home pulled plug on lower unit to check-full of water.
pulled prop and found fish line waded up on shaft. pretty sure this is what caused seal to fail.
my question is can i pry this seal out and get a new one in will i be good to go
also all i can find is the drain plug in the bottom of the drive. i feel like a dummy but for the life of me i cant find a fill level plug higher on the lower unit any info any one can pass along will be a big help.
THANKS
1. there are TWO seals. you ne
1. there are TWO seals. you need to pull bearing carrier to replace.
2. there is no level plug on lower. it's on the UPPER.
"3. The drain plug is the &#39
"3. The drain plug is the 'fill plug'... you have to fill these from the bottom up, using a pump."
"If you haven't already go
"If you haven't already got a manual, now would be a good time to pick one up. It'll tell you how to drain and fill the outdrive. Good luck.
graham"
