So i got my mercruiser 3.0 with alpha one leg all tlc'ed up, runs beautifully on the trailer.
First time at the jetty she was harder to start and eventurally gave up suspecting i flooded her. Pulled her out started her on the trailer,back home fired straight up.
(I know there two differnt playground for boat troubles)
Tried again the other day at the jetty,still hard to start but sucess!
Limped her around a little make sure she wouldnt cut out then went onto the plane for only about 300 - 400 meters in total.
She gave a couple of clacks/knocks at the start with a growing whined, pushed on for a little then backed back off the plane and she started to idle rough and i noticed the heat gauge had climb a fair bit (usually 1/3 unladen but now was 3/4) i didnt get a chance to pay attention to the rev gauge.
So back to the ramp and home.
I know the overheat is going to be a blocked manifold or screwed thermostat.
And i do have a crack in the lower housing along side the prop ( only an inch or 2 long) that could be causing knocks and resonating, just want to confirm a crack that small could cause these symptoms ? Before replacing the lower unit (500 - 2000! : ( starting to think ive bought a problem)
But also want to know what else i could do or look at to eliminate other causes before replacing the lower..
Also is there anything i may have missed ?
Action plan for now is;
Remove riser, mani,resivour - clean and regasket
Replace plugs because to be honest i should have done them before.
Contact a shop for 100 point inspection and possible consulting on housing repair if it can be done ?
Thanks in advance for any advice and wisdom
And i hope the speed im learning is leaving an impression
Still havnt got a manual
The rookie.
The rookie.
