https://picasaweb.google.com/113840...neOutboardMotor?authkey=Gv1sRgCIiOjeKhmf--0QE
The photos are of what I'm working on .
On the lower housing is stamped with the no's E463 54317
On the top and underside of the magneto is stamped Model No 61-M
On the magneto underside is stamped Serial No 47 A. This does not fit the way I have read these things are given serial no's.
I have gone through almost all of the motor and should be ready for a test run this next weekend. Can anyone give me tune up specs? (point gap, carb. settings?)
I'm puzzled on how to set the small needle valve with the dial face on the front of the engine. I have lightly set the needle valve on it's seat and then set the adjusting knob to it's lowest number setting.
What is the proper oil-gasoline mix for this motor, or what would you recommend I use?
Thanks for your help.
