Fired It Up Yesterday Had ProblemsNaturally
"1980 Mercury 90 HP Outboard
Model: 1090620 90ELPTO
Serial: 7179095
Reinstalled fuel tank and filled it with a fresh 50:1 mix. Put on earmuffs and started 'er up. Well , to start with, no pee. Removed lower unit and rechecked pump install. Found all ok. Pressureized water tube going up in engine with water, flowed good. Reinstalled lower unit, low and behold it worked, don't know why it didnt to start with. Guess I'm going to have to remove the carbs again and do a rebuild, guy from local shop told me to disassemble carbs and spray carb cleaner thru every open hole and it would be fine. But seems he wasn't right, now they leak fuel. When I had carbs apart, I noticed around the plugs there was some red stuff, some type of sealer I guess. I didn't put anything back on them. Was that possibly RTV sealant or what type would be recommended? He told me not to soak them, as it would turn them into a molten plie of metal. Would it be ok to soak the metal parts in carb dip? Seloc manual shows pics of parts in a soak basket. Also, I need info on where I can find correct brass parts (plugs, jets, ect.), seems someone in the past wallered out the slots. I also couldn't get one of the small ones out (probally needs drilled and extracted). I think the carbs are wmk-27 maybe, I'll have to check on that. Also my rectifier is shorted (have a new one on the way), and I ran it without the stator leads connected. Would that have anything to do with my Tach not working? Before I started it up, I fogged all the cylinders thru plug holes and whizzed her over, so cylinders wouldn't start dry. Is there a dial indicator setup that will screw into the plug hole that I could buy? Need to verify timing is set right. She seems a lil sluggish. But when I go back through the carbs, I'm gonna do the fuel pump also. All input is appreciated
"Soak basket is fine. Some of
"Soak basket is fine. Some of those parts can't be bought anymore. You have to find them. Brass plug's, ect.
The dial indicator was just to calibrate the plastic pointer.
Tach won't work without the rectifier."
Yeah I need to calibrate the p
Yeah I need to calibrate the pointer so I can check ignition timing. Is there a dial indicator set up a guy could buy to do this with?
I need to know what the plug t
I need to know what the plug thread size is on this engine. Also a dial indicator kit brand name and part number if anyone has it. Thanks for the input.
