Finding TDC for AQ260 Engine
sojourner
What are the steps for being able to manually turn over my AQ260 engine to fine my Top Dead Center. Do I pull off the water pump or just the impeller? Or is there another way??:cool:
Do what ever you can to not use the front crankshaft bolt for this. It is not intended to be used for this!
Try a strap wrench...... by hand.... bump starter motor..... ?????.... etc.
You'd be pulling your hair out if you were to break this bolt off.
