Finaly got a marine mechanic
jjdluz
"i have been play around mess
"i have been play around mess with my 1992 yamaha 200 outboard for pass 2-3 month,finaly got a marine mechanic look at the motor,i told home motor crank and run everytime,go out fishing and back no problem,and boat do plan out and can run wot,i tell u that is what he done,he check compression-all good,spark-all good,check spark plugs,all normal,timming -good,cd box-good,have fuel go to each cylinder -yes,but still the same cylinder unplug the coil have no chang the running,and he mess around the carb and coil,cant tell what is wrong,but he did said that cylinder got to be working,otherwise fuel will flood the cylinder,and he said the motor sounds good and run good for two stroke motor,anybody have any tips what is wrong of mymotor?or it just nothing wrong with it,thanks for all the help pass 2-3 months."
