Feul injectors wont sprayHelp 2000 250 hp
rustyamos
"Hey Guys, I have a 2000 250hp model sx250txry motor and we are not getting the injectors to spray. Test with node's and we are getting power on the hot but not on the ground side. If you spray feul in the air box it will run but I am being told bad C.D.I., I believe it is part # 65L-85540-01-00 and the best price I can find is $980 can anyone help in any way...
Rusty"
im having same problem i repla
im having same problem i replaced electric pump inside the fuel chamber if thats what is called i get fuel into chamber but not out to injectors is it electrical how do i check it? thanks
"Can you hear the fuel pump ru
"Can you hear the fuel pump run with ear near vst, with just key turned to on only? Be sure you have the proper o rings, and white plastic washers in place inside of vst, if you don't, you won't have the proper pressure to operate fuel injectors."
