Faststrike 150 1997
johnnyg
"My engines is cutting out at
"My engines is cutting out at random on top end---then it has a heavy gas/oil slick coming from the exhaust--it gradually gets back on plane and runs below 4000RPMs, but continues to leave the trail--help?"
if it is oil injected the orin
if it is oil injected the oring may have went bad in the oil pump allowing to much oil into gas and thats where the low performance comes from
you need to put a flow meter on it to track oil volume.
or just disassemble the pump and check the oring
the BOATINDOCTOR
