glen3536ski
Hi all, I went to start my 1997 fast strike 150 from cold 1st go didn't fire 2nd go it fired but didn't run, I went for the 3rd start and as it was starting to fire up it just stopped all the electricity to the every thing shut down. I checked the motor fuse and the fuses in the fuse panel all ok , checked the out put from the fuse panel all ok , checked connections of starter switch, gauges, throttle, connections on motor etc all ok. Randomly power returns this has happened 5 times over a 24 hour period. The gauges work lights work as I go to start it I turn the key the engine test lights light up the buzzer works it goes through the correct test sequence then when I turn the key to start all power stops nothing . There is power to the ignition key switch and the main cable to the starter. So it have been using a process of elimination so far with the same negative result, I can,t understand how the power returns it is almost like there is a thermal electrical cutout but I can't find one and I don't think there is one? So each time the power returns? I have disconnected sometime first I removed the tilt relays tried starting no good, then disconnected the main positive feed to the starter no good, removed the other 3 wired on the starter joined with the main positive to isolate the stater no good, I have now removed the 2 wires going to the starter solenoid and am waiting for the power to return mysteriously to test . I am trying to eliminate the starter as the cause. Any suggestions? Regards
