I've searched and read numerous threads on this issue, but I've seen several people with symptoms similar to mine but never saw what they did to fix the problem. Mine is a 1995 Johnson Faststrike 175HP. VRO system is still used. Boat hasn't been on the lake since last July....but ran flawlessly.
So today, I figured I'd put the muffs on it and crank it to let it run so I could resolve any issues instead of waiting until I was at the lake. Sure enough...issues have risen.
Symptom #1, the primer bulb won't build up/maintain pressure. It usually (always before now) pumps up firmly within a few squeezes. I can hear 'gurgling' inside the bulb....as well as 'gurgling' inside the gas tank.
Symptom #2, as I attempt to prime the bulb, I can hear a 'squeak' from a small vacuum hose. One end inserts into the intake silencer while the other plugs into the fuel (vapor) pump. Traced the noise to the actual pump. Almost sounds like a slate turkey call while I squeeze the primer bulb. I've heard that this is normal?
Symptom #3, If I squeeze the primer bulb long enough (again, it never tightens up), fuel pours from the bottom and middle carb on the port side of the motor. I removed the float housings from these carbs. The insides of these are practically clean as a pin. No trash or buildup. Actually took the needle-seat apart on 1 carb and saw no obvious signs of the needle/float hanging up or inability to seat fully. Turned upside down, the top of the float is perfectly parallel to the bowl's edge. That's where it should be, correct? Sprayed down with carb cleaner and wiped excess and reassembled. Can/will gas still flow from other orifices on the carbs even if the needle and seat are fully seated?
Symptom #4, The motor WILL crank and run for a few minutes, then die....and will not restart immediately. If I squeeze the primer bulb enough to get some more fuel to the engine....as long as I don't overdo it, it will restart....run a few minutes, then die again. All the while it DOES run, it smokes like a freakin tar kettle. I realize these motors will smoke some, but mine as always cleared up within a minute of runtime. Currently, it smokes excessively the entire time it runs....like it's severely flooded. As stated, the 2 carbs I disassembled were clean and saw no signs of the needles not seating.
I'm 99% sure carb rebuild(s) is necessary as I've wrenched on ATV, dirtbikes and cars most of my life. Working on boats is fairly new to me, but common sense tells me it's basically the same concept. Just need some guidance.
