timebandit
Advanced Contributor
Hi,
I have an F70 that will not rev over 3400. This is after changing the VST filter. The HP pump tested good. 70 PSI with the return line pinched.
The engine blew a 150 compression in every hole and is banging on all 4 when I pull out plugs for the injectors.
YDS has no codes TPS and shift switch is working.
Prop is a 15 inch wheel on a Whaler Montauk
What do I check for next?
