Bought this boat/motor about 4 years ago. Charging seemed OK, Tach worked.
Recently had burned out Rectifier/Regulator. Although it had lost Tach signal output some time back, when battery got low I found the Negative terminal loose which probably finished off the Regulator burning out (actually burned through the back cover black sealant).
Considering Yamaha OEM R/R was $200+, I bought a good used OEM R/R. Installed and when test running on water hose with battery charged to 12.7 vdc. When started the charging voltage was 14.4 and did not fall back to 12+ as would expected after running at Hi-idle a few minutes. Have not yet had it on the lake to give longer higher RPM run to see about charge voltage.
My SELOC Manual says the R/R output should be 14.5 volts, but that at 12.5 volts battery, charging should drop back.
Read on another post about a Yam F60 which routinely was at 14.5 volts.
My greater concern is if it continues charging at 14 volt beyond a short time enough to bring battery back to full 12.5, it will ruin the battery.
Anyone have any insight on this?
