Strange situation. Just changed the water pumps about a month ago, tested both and they ran great with strong water coming out the indicators.
Changed a fuel pressure regulator on the starboard motor yesterday and tested the engine and there was no water coming out. Just a couple drips. Waited about 3 minutes to see if the thermostat needed to open, but no joy. The engine sits in a 100 gallon drum for water.
Then tried the Yamaha Flush System, nothing, just drips. It has always flushed in the past with no issues.
Then left the Yamaha Flush system open, and started the engine, nothing. Water usually flows out of the flush input heavily when the engine is started in water. (Yes, never do this!)
Then I removed the lower unit and connected a hose directly to the input shaft that usually goes into the water pump. Water went into the engine, then stopped. A couple drips, out of the pisser but nothing else. When I removed the hose water rushed back out through the input tube like it is blocked.
So it can't be the water pump, for sure. Yamaha flush has stopped working. Water does not circulate when applied directly to the water pump input shaft.
These are great motors in great shape and very well cared for with about 600 hours. Salt water used but always flushed with salt away after every use.
The only things I can think of are 1) The Yamaha Flush system has been left open. A bug big enough to plug the whole system??? 2) Thermostat? But don't they always have bypass?
Any ideas are appreciated. Thanks
