A
aywolf
Guest
"Have a new 115..approx 15 hou
"Have a new 115..approx 15 hours. Was running wot and the motor quit. I checked everything and tried to restart. Motor ran for 2-3 seconds and stopped again. Waited a minute or two...primed the bulb and it fired up and ran normally. Went out the next Sunday and motor ran fine all morning. About mid day while moving at about half throttle, motor stalled again. This time I immediatly pulled the throttle back and the motor didnt cut off. Sat there and idled for a minute or so and went on. Ran normal the rest of the day. I am being told to remove the ant-syphon valve as this is the most likely problem. What do you guys think? When removing the ASV, what kind of sealant do you use when you replace the valve? Thanks in advance"
