Hi everyone;
First post here, but have been lurking for a while. I have a 1994 Grady White 192 Tournament with the original 1994 Evinrude 150 Ocean Pro. The original horn's speaker blew out, so I replaced it with a new one of the same type/model. This is the version with two male terminals and a ground wire. One terminal of course receives the tan temp sensor wire, and the other terminal receives the purple ignition "power" wire. I have the ground wire terminating at the ground "M" terminal on the ignition.
My problem is this: when I turn the ignition switch to the run position (i.e. the first click to the right), the warning horn beeps briefly, as it should, indicating it's working. Then, immediately thereafter, the horn begins a very rapid chirping. I estimate it's probably something like 2-4 times per second. It does not stop. If I start the engine, the rapid beeping continues. This symptom is the same regardless of engine temp, in the water or out (on muffs). Disconnecting the tan temp sensor wire stops the chirping, but it seems like a red herring, since this symptom occurs before the engine is even started and when it's dead cold. I've moved the ground around, just to make sure that's not the problem, and have observed the same symptom.
I've looked through the various threads that address continued beeping, but nothing seems to fit my fact pattern (i.e. the EXTREMELY fast chirping). Any ideas about what causes this and/or ideas about how to track down the cause would be greatly appreciated.
Thanks to everyone in advance!
