dagostino82
I would like to move my batteries from the stern to under the console. I have a 2003 BF225 with stock battery cables. It appears there might be a 2ga. positive from the starter and a smaller positive cable from the alternator that's splice into the same lug to attach to the battery. There is also the 2ga. negative. Can I just buy the battery post that Honda sells and then extend new cables from the post? I need to extend the cables approx. 13' more. What size new cables should I buy? I know you are supposed to increase the size when you increase the length due to voltage drop right? Is there going to be a problem not changing out the size of the stock cables?
Example: 10' of 2ga stock cable, Honda battery post, then 13' of (1ga or 1/0?) new cable to the battery.
Does this look Ok and what size new cable do I need?
Thanks,
Chad
Thanks,
Chad
