Thanks in advance for your help. I have a port carbed, fwc, crusader engine with about 900 hours that has a vd tranny slightly overheating with a little oil coming from the over pressure relief valve and some steam in exhaust. Over a two year period have replaced-oil cooler, risers, raw water pump, freshwater pump, new transmission oil lines to cooler, and finally we replaced the Velvet drive transmission. The temp on the tranny is 40 degrees higher than starboard and the temp at the thermostat on both engines is within a few degrees of each other with IR gun. As stated there is definitely steam on port side exhaust and we feel it is a flow issue but just can not seem to find the problem. Have also swapped out hoses so that the stbd raw water pump went to port and vice versa-no relief. Has anybody ever had an issue with output side of cooling flow and has that been an issue. The overall operating temp on port side is about 175 compared to 160-5 on other side with console gauges. Thanks again for your help
