S
steve hale
Guest
"Ok, since some of us are lear
"Ok, since some of us are learning (me) and some of us are teaching, I thought I'd share my most recent lesson. Here was the problem....
I installed a new heat exchanger and upon the first trip out I heard a little tick by the thermostat housing. After further inspection, the tick was water pulsating in the hose feeding the starboard manifold. I noticed the hose feeding the port manifold was quite a bit hotter than starboard. I thought maybe an obstruction in the thermostat housing and took the hoses off and touched my fingers together inside and noticed no obstruction. I took the port hose feeding the manifold off of the manifold and noted the flow of antifreeze and then did the same for the starboard. The flow seemed the same. My thermostats both read 155 the whole time. Then I decided I'm just going crazy stressing about every noise on the boat, and I am chasing ghosts. I almost made it to the end of the channel before my real problem made itself apparent. Any guesses before I tell you?"
