knuckle47
Advanced Contributor
"As the winter progresses here
"As the winter progresses here in the northeast. I pass what little leisure time enjoy reading this forum. I am still reading about exhaust steam posted by some and how eventually, someone ... somehow, develops a discoverable problem.
In the 2-3 years I have been using the forum and the Silverton club, I have yet to find the answer that says what amount of steam is normal or abnormal given the variables of the cooling system and water flow in FWC systems. I have totally removed the cooling system and cleaned or replaced everything.
I have seen many boats out there in summer "steaming" down the bay. Some days it is more than others. At idle, nearly nothing. At 2500 to 3200..I had to remove the swim platform mounted ice cooler as the 30-40 lbs of ice is 1/2 water within 2 hours. Is there a flow rate of sea water? A measurable temperature that eliminates it?
My boat runs perfectly according to specs after all of the help I have received here, and some of you know those events BUT...She is a "steamer" regardless of my persistence. IF it is normal to steam....man, no problem...However, if it is an indication of something NOT right...I gotta find right !
steam
