NautiqueThomas
Hey everyone, first post here and I am hoping you can help me out with a problem I am having.
I have a 2011 Nautique ski boat which has the 2010 Crusader 6.0L motor. Towards the end of last year I had an overheat and one of the exhaust risers cracked through inside causing the coolant to just run right through out of the exhaust even with the motor off. We replaced both the exhaust risers using the gaskets sent by Nautique. The mechanic doing the work had a hard time getting the risers to seal properly onto the exhaust manifolds and ended up using some gasket seal on the one side. Eventually they appeared to seal and we tested the boat and it ran just fine. I have been using the boat since and it has been running as before. The coolant level has not changed noticeably and I have done about 60 hours on the motor.
During the 60 hours performance has been normal but I noticed that on starting the boat first thing in the morning it would stutter occasionally and almost stumble to life. I feared that there was a small leak somewhere but the mechanic reassured me that if the boat was running smoothly it was ok. I winterised the boat and recently got it back out the garage for the summer here (South Africa). Before I ran it I pulled all the plugs and everything seemed normal. I also changed the FCC fuel filter and the in-line filter as I thought water in the fuel may be causing the bad starts. Today I took the boat out and inspected around that gasket very closely and saw a tiny leak on the outside. The boat was running fine and the leak appeared to be very slow. I remain concerned though...
- Is there likely to be a leak causing the bad starts on the inside?
- Have I caused damage to the engine by running it with this leak for 60 hours?
- What are the correct gaskets for this engine and what is the recommended way of getting them to seal properly.
I really appreciate any help with this one and I apologise for my somewhat limited mechanical knowledge. Let me know if you need any further details.
