fastjeff
Gold Medal Contributor
"Boy, are you lucky! I have ri
"Boy, are you lucky! I have risers and elbows on both sides of both engines: 4 times 250 bucks each time they go away.
If I were you I'd put new manifolds on it. Why take a chance? Why? If the interior of the manifold develops a leak, water drips down and goes into the cylinders. The way yours is set up (and brilliantly!) the maniflds probably drain when the engine is shut off--ordinarily the water remains in the manifolds to leak into the motor. That said, I'd still change 'em out.
Jeff"
Jeff"
