"After going back and forth, I
"After going back and forth, I'm going to replace exhaust manifolds, elbows and risers on both engines. I'm doing all the work so the cost won't be too bad...
I have a couple of questions:
1) what should I do in order to prep for the exhaust manifold removal? The bolts look like they're pretty far in, I don't know if PB Blaster will do any good.
Ease them out with a 1/2" breaker bar and
socket? Do I have a chance in getting 4 of
them out w/o breaking a bolt? The hull side
of the engines scare me a little especially
if a bolt breaks.
2) If I'm replacing the riser AND Elbows, there's no reason to seperate them when they're coming off right? Can I just bolt the NEW risers/elbows together and install as one unit?
thanks,
Bob"
if a bolt breaks.
thanks,
Bob"
