I have 1985 454 model 350 engines FWC. Around 700 hours.
Stbd engine was running 15-20 degrees hotter than port engine. I replaced the raw water impeller (found one torn vane) and U-Cooler, and that helped, now running 10-15 degrees hotter. I used my IR gun to check various temps and found that the hottest spot (top rear near the water discharge connection) on one exhaust manifold was 200 while the same spot on the other manifold was 190. This measurement was taken at the dock running about 1500 rpm. Is this normal? Should I suspect a blockage in the manifold and tear it apart? I believe the manifolds are original, but the risers have been replaced. I also see a bit more steam (and soot) from the starboard engine at cruise. My domestic water heater is conected to the port engine.
Thanks!
Thanks!
