Exhaust Elbow Gasket
bford100
"Is it recommended to use gask
"Is it recommended to use gaskget sealant on elbow block off plate and gaskgets on each side of block off plate? I hear some people do and some don't. If it is recommended what type is used? And when replacing manifold studs that hold exhuast elbow, should thread sealant be used?"
"4 years ago, I went with dry
"4 years ago, I went with dry gaskets on new manifolds and risers. everything new, including block off plates. I wasn't happy with the results; rust out to a couple inches away from the joint, but no obvious dripping when running. i even had to sandblast the manifolds to prep for painting. I'm now using fresh ultra copper RTV, very, very thin on both sides of both gaskets. so far, so good. Yes, i use thread sealant on the threads, although you don't need it for sealing, you may enjoy the easier removal later. I'd use either permatex 2 or 3 or even blue locktite."
