Exhaust bellows adhesive
jerryh
I'm installing all new bel
I'm installing all new bellows on a alpha 1. Is it nessesary to use adhesive to the exhaust bellows and why? It's not water tight anyway. Also what keeps the water from leaking up through the shift shaft and into the U joint bellows.
"the adhesive,helps to hold th
"the adhesive,helps to hold the bellows on,we put it on all bellows...the shift shaft,is no-where near the u joints....if u are referring to the shift CABLE,it takes a small bellows."
