Exhaust Bellow Removal
tjwc1
"Been looking thru the Seloc m
"Been looking thru the Seloc manual for a proceedure on changing the Exhaust Bellow out. I cant find a proceedure, Do I have to remove the Outdrive or can this be done with out removing anything, thanks TJ"
"Just lift the outdrive, unscr
"Just lift the outdrive, unscrew the two hose clamps, remove the exhaust bellows, install a new one with the drain hole pointing downwards (you may need to lower the outdrive for this), install the hose clamps in the correct position (check Seloc) and tighten them.
That's all."
