Excess smoke from outboard
"I have a 1993 johnson 150hp o
"I have a 1993 johnson 150hp outboard, and have noticed when its running at idle that sometimes it smokes alot, and other times it doesn't. The smoke is blue in color. The vro/fuel pump is hooked up and working. Any idea what the problem might be? Also at first start up she'll smoke alot too."
"this is fairly normal on a 2
"this is fairly normal on a 2 strk....your only choice,as i see it,...is to run an oil consumption test on the vro,or replace/rebuild it.U will def need a FACTORY service manual."
"Adding on to what jwb said th
"Adding on to what jwb said the oil consumption test is pretty straight-forward.Attatch a 1 ft.long 1/4 I.D inch clear tubing to the oil intake of your vro (forward most fitting),(fill w/2stroke oil before attatching,mark hose at1\2" intervals) start motor,observe oil dropping in tube while pinching gas/oil mixture output line (the one going to carbs) to feel for pulses.Oil level should drop 3 inches in 6-8 pulses approx 1 min. "Don't quote me on the time""
