dhearn0513
I have an 85 Evinrude 120, that I disabled the VRO on. It will stay running as long as you pump the BULB on the fuel line. When you stop pumping the bulb it will run for about 30 second give or take 10 sec and then shut off. It will not start again until you prime the bulb again. I have check alll the fuel lines for crack, because I first thought that it was an air leak for something. I'm starting to think its the fuel pump. I primed the bulb and then took the fuel exit line off the top of the fuel pump. It did pump fuel but not continuously, Is this normal for these pump. Its almost like it pumped fuel in pulses...
