EvinrudeJohnson pwerpacks
ckav8r
Is the wiring the same on the
Is the wiring the same on the old screw type v4 powerpacks? I have a spare factory but the ground wire is in a different location than the CDI replacement pack
I have never seen a 581731 scr
I have never seen a 581731 screw terminal powerpack whereas the wiring would be different. Are you sure that's a V4 and not a old type V6?
The OMC pack # is 582056. Anyo
The OMC pack # is 582056. Anyone have a picture of the cover with the screw terminal placement?
"Pack #582056 first came into
"Pack #582056 first came into play in 1976, continuing thru 1977 and is a screw type V4 powerpack. The black ground wire would connect to terminal #6 which would be the bottom right terminal."
"The 582056 pack I have has a
"The 582056 pack I have has a ground wire on the upper right or when flipped over on the lower LEFT. I do not have a cover for this pack, so I don't KNOW where all the wires go. I could copy the one on the motor for wire placement, but I do not want to fry the pack by hooking up the wires in the wrong order. If anybody has a cover for a 582056 I would appreciate a picture of it, or a diagram. I received a response on another website that the ground wire should be at the lower LEFT side. Joe was kind enough to tell me it belongs on the lower RIGHT. (which is where the aftermarket pack has the ground). Please help me out.
Chris"
"Chris,
I sent you a pictur
"Chris,
I sent you a picture of a 1975 135 (0581311)
powerpack. This powerpack cross-references with your #582056."
