"The motor was from my uncle t
"The motor was from my uncle that passed. It has been sitting in a barn for 15-20 years my aunt said. I drained the gas, blew the fuel line from the tank to the carb out and let freash gas run thru the line. I also poured water thru the water flush screw and changed the lower end grease. I noticed the carb is leaking at the seal. Is there any where I can get a carb kit? Also any info on the fuel mixture and where to set the fuel mixture screws to get it to start. I just wrapped a rope and pulled it over a couple times. Also what spark plugs and gap does this motor use? Any help would be greatly appreciated Thanks."
