I just purchased a used powerhead off ebay for my 1993 Evinrude VRO 40 hp. When I first got the powerhead, I spun the flywheel and it seemed to be free. I let it sit in the garage for 3 weeks an installed it to find the flywheel would not turn by hand at all. I put a little oil in the cylinders and gently worked it back and forth until it freely spun by hand again without the spark plugs in. I did a compression test to see if it was damaged and I got 130 PSI on both cylinders. I am ready to install the lower unit and try to start the engine, should I be concerned about anything on this power head before I start it up? The power head came from the east coast which is lower elevation and more humid than the dry high elevation desert I live in here in Utah. Would this have affected the motor? When I do start the engine I plan to run seafoam through it to decarb the engine. Any thought?
