"Not sure what happened to my
"Not sure what happened to my last post. I need to know if there is a way to check AC voltage from stator. Working on a 1977 Evinrude 85 HP. I think I just connect at yellow/strip and yellow wire from the stator with ac voltage tester, is this correct? Can I also connect to the brown and brown yellow to the power pack for the same test? I am also not sure about the hookup, just to both wires or from one to ground through the meter, also what volts will get at cranking speed? Any help would be great, I have done all ohm resistance tests for stator/sensers and they check out fine. I have weak spark with plugs out and fresh battery at cranking speed. I think I have it narrowed down to the power pack, but this last test should confirm, I think. thanks Larry"
