J
John D.
Guest
"Hi,
I have a 99 225 that jus
"Hi,
I have a 99 225 that just quit out on the water and now wont even attemp to start. I bought the software to check out the problem. The first time I ran the software I got 7 intermittent codes 16,81,82,83,84,85&86. The 16 refers to the crankshaft sensor not being gapped correctly or failed. The others are for each of the coil packs. After looking over the crank sensor I relized it hadnt move out of adjustment. And there was no reasonable reason for all the coil packs to go bad at once. So I checked all the fuses and they were good and I checked the crank sensor and it tested good. Then I cleared all the codes and attempted to start it again and got just the codes 81 thru 86. Is this telling me that the emu is bad or is there a code the actually tells you when the emu is bad ? Any & all help is welcome !!! Thanks in advance !!!"
"Hi,
