"Posted on Wednesday, August 1
"Posted on Wednesday, August 12, 2009 - 01:56 pm:
evinrude model number CE60TLCCR.
Just bought the boat and motor at an estate sale.
Was told it has not been run for a couple of years but was stored properly when put away.
Changed the gas can, bulb and hoses along with new plugs before I even turned it over.
First off the outer cover says it is an evinrude 70 VRO however, looking up the model number I see that it is a 3 cyl 60hp. How can I confirm this is a 60 and not a 70. serial number is C7230633. I also mix my gas and cannot even see where an oil tank would be on the motor so I am assuming that VRO is non existant.
Put it on the water and went out to play, first off I noticed idle was too high and after about 15 minutes of full throttle operation engine acted like it lost a cyl. Do not know why. Brought it to the shop and the carb linkages were adjusted and timing was set up ( supposably off)
went back out and cyl dropping out problem was gone but motor does not like to run at slow speeds, idles down like it is running low on fuel then dies, restrting it after this happens is usually difficult.
I was told to rebuild thwe carbs and reset up. I am not really familier with marine mechanics so I thought I would get some opinions.
lastly, I am told that it does not have a choke but a fuel enrichment system which is electrically actuated, The control is on my console coupled with my key, (ignition says push to choke) my question wopuld be if I push and keep pushed does the enrichment system keep pushing fuel into engine or does it operate like a primer, 1 push means 1 pump
Any help would be greatly appreciated
Thanx
D...."
Thanx
D...."
