Evinrude motor year model
tobym
hi to all from aus. can someo
hi to all from aus. can someone tell me the year model of this 6hp e/rude engine.mod no. AE6BACDE. also 55psi on both cylnders[is this acceptable] having starting probs.plenty spark and fuel.have checked r/valves ok. dont know about secondry compression.what are timming settings at idle and wot thanks toby.
"Hey James,
your model numb
"Hey James,
your model number breaks down as follows:
A - Austrailian built
E - Evinrude
6 - horsepower
BA - AC Lighting model - Rope start
CD - 1986 model
E - model run suffix (no meaningful data)
Your compression sounds low, but may simply be the way your gauge reads - I would expect somewhat above 90 psi on each cylinder for a motor of this size and age..."
hi graham thanks for the info
hi graham thanks for the info on year model.comp on both 55psi probly a bit low [done teaspoon oil in both cylnds but never raised comp].i thought 55psi on both would be good enough for engine to start. thanks
"james, a decarb would probabl
"james, a decarb would probably help. heres a link http://forums.iboats.com/showthread.php?t=158076
and you can go to google books and get partial repair manuals....i know they have the timing spec.......but you dont set it at idle.heres a link for that http://forums.iboats.com/showthread.php?t=228183&highlight=joe+reeves+timing+met hod
and heres a couple more you may be interested in....about motors that have been sitting and how to set your carbs
http://forums.iboats.com/showthread.php?t=244013
http://forums.iboats.com/showthread.php?t=167352
http://forums.iboats.com/showthread.php?t=158086"
"Yes, decarb wouldn't hurt
"Yes, decarb wouldn't hurt - but I would still be suspect of the gauge.
I have 2 gauges. On the same powerhead one reads 65 psi the other reads 95 psi - which is correct? Neither one - tried yet a third gauge (one calibrated at a local small engine place) and get readings of 100 (cold)..."
thanks for feedback chkd comp
thanks for feedback chkd comp with replcmnt gauge 56psi on bth cyls .2ndry comp ok will operate f/pmp.and good suction at carb mani/fld.checked timing with t/light both cylnds on time at idle and full/adv.all done by elect/drillwith 19mm socket turning f/wheel .still having start problms thanks
hi to all. have finally found
hi to all. have finally found the problem. removed the head and found compression was blowing between the cylndrs the head was warped done a resurface job and reassembled. compression now 105psi and engine starting ok.
thanks for your feedback
