Evinrude motor issues
yldman4
I recently purchased a 1990 Ev
I recently purchased a 1990 Evinrude 175. Prior owner said the motor started and idled perfectly but wouldn't run at top end. He also stated that when the choke button is pushed while running - the motor would speed up. To me that indicates fuel pump or carbs.?????
I am looking for some feedback on this problem and appreciate any advise I can get .
Thank you
To me it would suggest a carb
To me it would suggest a carb problem. Be prepared for a bit of carb cleaning.
Operating the primer(choke) manual lever should also produce a response.
If a pump problem pumping the priming bulb in the fuel line would probably overcome it.
"1973 Evinrude 18hp 2cy. - my
"1973 Evinrude 18hp 2cy. - my motor "clunks" or bucks outward when I am going ahead at higher speeds. Acts just like I hit something in the water! Starts easily and trolls well. Can someone pleeeeeeease help me solve this annoying bucking problem!!!please e-mail me at [email protected] with their suggestions Thanks. handnhand"
"Thanks to all who replyed to
"Thanks to all who replyed to my need & I have resolved it now so thanks once again!! And yes it was the gears & dog clutch that was causing the problem !! I replaced complete gear box etc.!
