Evinrude model 2202 setting points 2 HP
jcibella
"When setting the points I fin
"When setting the points I find the high side on the crank lobe to open the points. Next I use a feeler gauge .020 and adjust gap. Where should the stator/throttle plate be set at full throttle,run,or stop? By move the throttle it seems to advance the timeing. What is the correct way to set the points? Thanks!
"It doesn't matter where t
"It doesn't matter where the armature plate is when setting the points.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
"i,by habit,just always fully
"i,by habit,just always fully advanced stator plate,as it holds it nice and still,while making points adj.."
